My VR4 has become a headache
Hey good people, i am new to this forum. I own a 1997 galant VR4 which is giving me a serious problem. Let me give you a short history.
2007, original engine knocked so the car was fit with a 4G63 SOHC V6 Engine.
2011, i decided to return it to its lost glory, Fit it with the original 6A13TT DOHC v6 Engine and gearbox.
All has gone well with a few problems here n there but there is one issue which i have been unable to sort out, the vehicle runs and idles well without the Airflow sensor but the second i connect it the car goes off, as in it does not idle with the airflow meter connected, the engine comp has been checked and given a clean bill of health.
Could the injectors be the problem? i just recently bought a used airflow meter but nothing has changed, the car just does not want to work with an airflow.
PLEASE HELP!!!!
AnotherNewb
Orlando, FL
/ubbthreads/images/graemlins/confused.gif
1)This forum is for the 89-93 Galants.
2)The 4g63 is a 4 banger, not a V6
3)You most likely have 2 bad maf's or the incorrect maf.
GL
DR1665
Iowa City, IA
Wow. There's a Galant VR4 in Kenya. The world is pretty awesome. /ubbthreads/images/graemlins/applause.gif
I will agree this is probably a problem with the MAF sensor or wiring. My first course of action would be to carefully inspect the condition of the wire harness and the contacts inside the connector on the MAF. If someone tried to force the wrong connection, there could be a short between pins, ya know? Otherwise, you might need to replace the MAF entirely or consider switching the car to speed density, which replaces the MAF with a MAP (manifold absolute pressure) sensor and an IAT (intake air temperature) sensor, which may be easier to source, although it requires changes to the ECU to work.
Good luck. Cheers from Arizona.
Lukefraizer
Fort Collins CO
Quoting AnotherNewb:
GL
I think you could have put that a little more kindly... I mean someone on here might know whats going on with it. I think it is completely ok.
