My stock 90 JDM GVR4
Ethan
Active member
Yangon/Myanmar
Here is my stock 90 JDM GVR4.
And, following is the stock list. /ubbthreads/images/graemlins/grin.gif
Engine block
Stock (with ECI multi manifold)
Use Idemitsu 5W-40 Fully Synthetic
Ignition system
NGK BPR6ES
Autolite Pro Fit 8.5mm
Intake system
Stock
Exhaust system
Only De-Cat
Turbo system
Stock with HKS Turbo Timer
ECU
Stock
Drivetrain
Stock with Automatic Transmission
Use Diaqueen ATF fluid
Suspension system
Stock
Custom make bushing (not good quality)
Michelin 205/65/15 And JJ 15"x6.5" Wheel (Finding 17" wheel)
Use Elf lubrication
Brake
Stock with MK Kashiyama pads
Petronas DOT3 Fluid
Cooling system
Stock
Use Diaqueen coolant
Interior
Factory stock (Digital climax control)
LED light
Exterior
Factory stock
LED light
A/C, ABS, 4WS, Stereo - Fully functional
Mileage - 46,000
2000GTX
Milwaukee, WI
oh my god the neon
Why did you go with the need for speed 15 year old look?
And the headlights.
Oh god why.
Ethan
Active member
Yangon/Myanmar
Cos of our country's Car clubs' culture.
btw: I already removed those tint from headlight.
And, regarding with light. It is cheap LED, not Neon.
Anyway, I have plan to remove LED at exterior and install extra fog light.
Interior LED are for function. I installed them with switch mounting at dashboard. Those help me alot in dark place. /ubbthreads/images/graemlins/grin.gif
2000GTX
Milwaukee, WI
Yeah that does make sense. /ubbthreads/images/graemlins/laugh.gif
Well it's a 6th Gen Galant so I like it either way.
Quoting Ethan:
