Mr187699
GVR47111K
80022, CO
I've got the bolts now, as well as that tap because the P.O. put on a tubular exhaust manifold matted with a 16g and now the factory bolts wont screw in properly through a 2g exhaust manifold to said turbo. Is 10x80 the same size as Terrerja Macho Inferior 10mm - 1.25? Am I going to seriously f**k something up doing this? Are the threads of the bolts and the threads of the taps the same, coarse or fine? What is the difference between the tap and the bottom tap?
You need a third number to fully describe the bolt, as in the thread pitch. Diameter of the bolt is 10 mm, length is 80 mm. Pitch is probably the same 1.25 mm as the tap, but put the tap and bolt threads together to make sure. If they nest, they are the same.
