Motor/tranny vibration but, pressin the clutch....
broxma
San Antonio Tx
...and viola it goes away. I just got the turbo installed. I am yet to get the final pictures for the setup but will post them in my build log shortly. Anywho...
When I start the car she is fine. I say "she" because I have given her the name or "Raggedy Anne". Regardless of the naming structure, Anne is fine with the clutch pressed in. Engine is smooth as it ever has been, however once the clutch comes out it slowly, sometimes suddenly begins to vibrate the entire motor/tranny, badly.
Again, clutch in, goes away. Now my common sense tells me that having the clutch out, I am connecting the flywheel thus the motor, to the tranny through the disc. With the clutch in, the connection is broken. In either position the flywheel and pressure plate would be spinning with Engine RPM. The only thing which would then be off balance would be the disc itself or something in the transmission.
The tranny is a new Stage 2 ShepTrans with about 400 miles on it. I am at a loss for what it could be. It is bad enough video of it would be rather conclusive. Maybe I will get some to show the masses what I am trying to say so that a solution can be plotted. As of now, the current solution is take the tranny off which I am not looking forward to.
/brox
broxma
San Antonio Tx
I believe after some thought I know what is happening. The flywheel is either coming loose of the aluminum is starting to give at the bolt holes. When I press in the clutch, the TOB presses against the plate, pushing the flywheel into a normal position, hence, the vibration goes away.
I'll be dropping the tranny in the next day or so and I expect to see either the flywheel in need of replacing or some bolt on its way back out.
/brox
broxma
San Antonio Tx
I didn't. I used the factory bolts. I'm going to be working on the Evo tomorrow but will be taking the tranny off in the next day or two. I may try and find one of the 6 bolt AT flywheel rings at the yard.
/brox
mitsuturbo
Near Seattle, Washington
The last time i saw this happen on a car, it was a 2g gsx. Turns out, a couple of bolt holes stripped on the aluminum flywheel. The owner was pretty pissed that his new fidanza was shot.
