MMCD fuel logging problem
James
Port richey Florida
Ive been trying to get my low trims adjusted for cruising around but my car is just a big bitch and does everything possible to throw curve balls.
I have my SAFC2 points set like this
1k
2k
3k
3.2k
3.4k
3.6k
3.8k
4k
5k
6k
7k
(PROBLEM1)
Now I sit in the parking lot car all warmed up and hold the idle at 1k RPMs. The low fuel trim (lft) goes to 112% so I adjust to something like +8% on the SAFC2 and it comes down around 100%. Now I move up to 2k and the lft jumps to 135% and no amound of adjusting brings in down...
(PROBLEM2)
Sometime the fuel trim will get locked into place. While adjusting it will just freeze on a number and not adjust anymore. Right now it's stuck on 110.4% no matter what rpm or what adjusting I do with the SAFC2.
I think problem2 (and maybe problem1) is related to my "hopefully phantom" knock. Sitting at a stop of I give it some throttle I will read between 10-40 counts of knock. When it get all this knock it adjusts the timin to crazy amounts. 20-30 degrees depending on the knocking... Obviously this has to have some effect on the ECU and fuel trimming
I never adjusted mine by free-revving it at certain RPM's to dial in fuel trims. Like I said in the other thread where you asked about this, adjustment around 1k work well for low, 2k works for mid, and 3k and up for hi. Why it works well like this, I don't really know. But I've done it this way to both my cars and had fuel trims that always would hover around 100%.
Do it like that and drive around. If you see that your low trim needs adjustment, adjust the 1k setting. Don't worry about what it does while free-revving at 2k. That's not how you drive the car, so there is no need to adjust fuel for zero load at 2k rpm. If the mid or high trims are off, adjust them at 2k and 3k respectively.
Also, rather than having all the little adjustment points in the 3k range, use a couple down around 1k and then spread them out in increments of 500. It helps to dial in idle and the low trim better. So like:
800
1000
1200
1500
2000
3000
3500
4000
5000
6000
7000
Something like that.
As far as phantom knock goes...that's a bitch. The only way around that is with a custom chip that has been programmed to ignore it or use ECMlink and adjust the parameters at which the knock sensor picks up knock.
