Misterfixit's information archive and scans index
misterfixit
Midlands, UK
Hi all,
I've been posting here for a long while now, but I get very confused as to what I've scanned and posted.
so i'm writing this as an index to help me (and you guys) find the posts I've made. It's not a complete list as i have posted some stuff I can't for the life of me find.
Mitsubishi PR mags:
Brochures:
89. AMG click
89.10 AMG click
90 SUPER VR4 click
88.10 COTY click
89.10 VR4RS click
90.10 VR4MONTE click
89.10 FULL BROCHURE click
89.01 UK click
90.04 UK click
90.08 UK click
91.10 UK click
90 PHIL GTI click
90.10 FULL JDM click
JDM ACCESSORIES click
Parts Manul Scans:
JDM Parts Catalog: Model Specs, Option Codes, Vin Boundaries: click
Service Manual Scans:
CLIMATE WIRING SCANS, click
REAR WIPER, click
FOLDING MIRROR, click
rear foglight wiring, click
BODY MEASUREMENTS, click
SIDE AND REAR BODY MANUAL, click
sunroof mechanism, click
jdm projector fogs, click
Heated mirror wiring, click *edit*
89.10 cyclone and mpi wiring and component layout, cyclone torque specs. click **edit 2**
Climate wire loom annotated, RHD 89.10 fuel gauge circuit click **edit 3**
Front body manual. Construction and weld diagrams click **edit 5**
misterfixit
Midlands, UK
Here are my set of JDm shop manuals (they are not all scanned, its a very big pile) But its a heads up of what is available at request!
The manual trans manual and the engine manuals are already available in the library.
Rich
misterfixit
Midlands, UK
**Continued from above**
90.10 Config diagrms and A/C wiring (manual type a/c JDM 4G63 T/C) click **edit 6**
Ignition Switch lock illumination: click **edit 7**
87.10 Engine management N/A 4g63 dual board: click **edit 8**
90.10 JDM IR Keyless entry. Tech, Shop, Wiring. click **edit 9**
Factory badge Locations. click **edit 10**
89.10 AMG Engine Wiring click **edit 11**
89up UK and ROW non cat fuel injection AFR setup click **edit 12**
ISC Solenoid service letter click **edit 13**
Jdm Folding Mirror construction click **Edit 14**
The posts i'm sure I made but can't find are the scans of the headlight washers. headlight levelling system, and bumper construction..
*Edit* also posted to the library are the JDM trans manual, JDM engine manual and Homologation Papers.
**Edit 2** added cyclone/engine management scans
**Edit 3** climate wiring loom/ fuel guage circuit added
**Edit 4** Parts manual Option codes and Vin/Prod'n boundaries added
**edit 5** Front body manual and weld diagrams added
**edit 6** JDM 90.10 config and A/C diagrams
**edit 7** Added ignition switch lock illumination
**edit 8** 4g63 N/A dual board 87.10 MPI system
**edit 9** JDM IR keyless entry.
**edit 10** 87.10 89.4 89.10 Factory badge Locations. Also 92 Mirage/Lancer CA-CD Badge Locations.
**edit 11** 89.10 AMG Fuel Injection Wiring.
**edit 12** 89 up UK and ROW non cat AFR setup
**edit 13** ISC Service letter
**edit 14** JDM Mirror construction
Hope this helps.
Rich
misterfixit
Midlands, UK
Checked back after a little while and loads is missing here, so lets add these in too:
89.01 EDM (NL) Hatch Brochure: click
89.03 EDM (NL) Saloon Brochure: click
89.06 JDM Galant click
1989 NZDM Galant Brochure: click
91.06 Galant Freindy E37A (Scroll down): click
Power steering pump seal sizes and locations: click
Thai E3x Brochures here: click
misterfixit
Midlands, UK
EUROPE, GCC, AUSTRALIA, NZ, HK, Singapore, General Export Models Service Manual. (LHD and RHD)
Wiring Manuals:
Top Row:
EUROPE, GCC, AUSTRALIA, NZ, HK, Singapore, General Export Models Service Manual. (LHD and RHD) 88-90
Bottom row Left to right Books 1&2:
GCC, AUSTRALIA, NZ, HK, Singapore, General Export Models Wiring Manual. (LHD and RHD) 91-92
Books 3&4:
EUROPE Wiring Manual. (LHD and RHD) 91-92
It might be possible to order these from the dealer still. I've replaced the copies with proper books over the years. Here is the order you have to do for these:
This dealer channel book in the UK didn't include the two lower left books, these were sourced elsewhere.
I've looked through the German Language manuals and they don't cover the non european non left hand drive cars which is a shame really.
