Missing Parts, Need Help
VR4Scott
Orlando, FL, USA
I am finally getting around to putting the car back together and I seem to be missing some parts to mount the front bumper. In the pictures you can see that there are some missing pieces from the bumper. I bought the angle pieces already from JNZ. What can you see is missing? Anybody have them or part numbers for them?
JDM bumper?
If so, you don't use the crash beam. You need to remove those two brackets from the car where the studs stick out forward, then the piece you see on the left side inserts into the rail (you may need Curtis bumper brackets if you don't have the originals).
VR4Scott
Orlando, FL, USA
Yes, JDM bumper. I'm trying to find what is missing from the cover. I see there is framework and a slide on the left side but nothing on the right. Anyone have the other side? Or part numbers?
Lancer99
Somewhere over the rainbow
Yea JDM bumpers just have a small piece on top just to hold the bumper cover. Unlike the usdm which have a crash beam that weighs about 50lbs I think. ^ and I don't have the part numbers for the side supports, it could be the same as a usdm. I would have to take a look at mine.
I am pretty sure the side supports, both horizontal and vertical, are different from US versions.
strokin4dr
Savannah, GA
Looks like you need a whole new bumper support. That one has been completely hacked up and half of it is missing.
Also, to install a jdm front on a usdm car, you have to remove the metal support caps from the front of the frame rails (the white things in your pic with the stud sticking out the front of them) and install a jdm bumper brackets or Curtis brackets if you can find them.
VR4Scott
Orlando, FL, USA
I got a set of the curtis brackets. I am looking for the parts that are missing from the bumper cover. Where can I find a diagram of the jdm bumper cover so I can find what I'm missing?
cheekychimp
East Sussex, U.K.
Quoting AnotherNewb:
Yep, front bumper support is missing. What headlights are those?
Scott, you are avoiding the question ... spill the beans!
VR4Scott
Orlando, FL, USA
Quoting cheekychimp:
They are 93 headlights that the previous owner took apart and painted the inside black.
Wookalar
Arizona USSA
Quoting strokin4dr:
Interesting. Are they actually usable since they can longer reflect the light?
Nope. Been there done that with the "chrome" spray paint. You can see pics of the ones I did in G's album or by searching for the japaneseclassic car show in 2012, some people photoed the car. There are a few pics of it at Japanese nostalgic car and on canibeat.
I imagine the black housings would be worse than the silver ones I did. They will show light when you look at them but behind the wheel there will be hardly any light beam. There is a reason why those old housings NEED to be chrome.
