misfire with COP setup
galant651
twin falls, idaho
just installed a used COP setup. went in great, look great and runs awesome except at cruising speeds, slight accel and slight decel, it starts to misfire. its really starting to piss me off especially when 45 out of 50 miles daily is on the interstate. any help is greatly appreciated.
i know all the coils and wiring is good because it idles perfect and does great under acceleration, its just when you start to level out it starts misfiring.
LIV4PSI
O-H-I-O
It's a common problem with COP setups. They should be ran with an ARC II ignition to actually be an upgrade.
Did you check your spark plug gap?
Brianawd
Portland OR,
what coils are you running? You may need to replace the boots and coil leads that go to the plugs. I had to replace mine once a year. They are cheap at carquest or any other auto parts store. I ran mine with No CDI box plugs gapped to 26 running e85 at 30psi. Mine was the BR unit.
Gizmovr4
andover,NJ
I have been running Curtis cop for a few years in 431 without additional ignition box- no issues to 43psi. I would check as others said : plug gap, coil boots&spring.I did have one of the ground wires get caught under the cop plate - causing misfires.
galant651
twin falls, idaho
first thing i checked today was my gap. somehow it was around .015. not sure how, bumped it up to about .03 and it runs alot better. i still have a fairly consistant misfire at highway speeds though but it is good now every where else. the weird thing though is its only at cruising speed and works great at high load.
galant651
twin falls, idaho
i havent been using dialetric grease, but i think i about got it nailed down. i checked my tps and my timing. tps was a little bit high but im happy with it. went to check timing and forgot i dont have wires! so i started changing it listening to my exhaust beat. got it pretty good and went and drove it. drives alot better, idles alot better and hardly any miss. turns out i was a couple degrees to far advanced. i might retard it just a little bit more and see how it does. but im satisfied for now. thanks everyone for the input and info.
