Megan o2 housing
coyotes
Seattle, WA
So I'm picking up some stuff for my car this sunday:
-Big 16g
-Evo III manifold
-Megan o2 (attached to turbo)
I'm curious about the o2 housing. Any opinions, information? Worth running or should I just use my stock o2 housing? I always like to hear the hardline VR4 forum opinion of things over the mixed information on DSM forums. Though everyone seems to like this piece.
Thanks
MHI EVO3 is what I have. Highest flowing cast piece. Still available from the dealers, you'll need a part number. I can get you one if you want. The downpipe flange is a little different and you'll need to have the flange rewelded for best fit.
I prefer the cast as it won't crack like some stainless ones will. If anything, get a 2G, it's a direct bolt on and will flow way more than a ported stock piece.
coyotes
Seattle, WA
I can probably get a 2g o2 housing, but this one is already attached and I may not want to deal with risking damaging hardware trying to remove it in case things are stubborn. But if it's junk I can get something else.
BENE38A
New Zealand
bit of wd40 or some other penetrating oil and i have never had trouble splitting exhaust parts, i dont know whether these s/s jobbys are shite over in us but here they are crap, they crack and aint always "stock replacement"
WaRrIoRs16
Ferndale, WA
I have had the Megan racing o2 housing for a few years now. My only complaint is that I kept losing alternators due to the heat from the o2 housing. I went and got some sheet metal, and bent and cut it up to make a heat shield and the alternator hasn't had any issues since. It bolted up to my downpipe okay, one of the bolts is a slightly more difficult to tighten, but its manageable.
strokin4dr
Savannah, GA
I had one of those SS o2 housing that came in the parts pile with my car. It took out the frist alternator in no time and then almost fell off the car from all the cracks at the turbo side flange not long afterward. Stick with a ported 2g elbow. I will from now on for cars with oem turbos.
