Mega Squirt help
Looking for help to get this up and running. I have it all installed and she starts but stalls out about three seconds after starting.
I am running
550 inj
MSII V3.0
Miata/4g63 trigger mod
firmware 303r
GM sensors.
No EGO sensor at this time
Idle control disabled for now
Just want to get it idling and go from there, This is a hell of a learning curve and quite honestly I am a little lost on where to start.
Rob
ilotalo
Member
Lappeenranta, Finland
Dose your fuelpump run after crank? In my galant i had to make extra relay to get fuelpump running after crank. Megasquirt controls fuelpump GND and original ecu +12v. If i remember right.
That problem sounds just like mine before that mod.
janne
Nope got it, I had misunderstood the manual and had it set at alpha-N, changed it to speed density and bada bing started right up and continued to run.
Do you have good base maps by chance?
By the way I modded the relay to a daisy chain configuration, It is real nice and it can be replaced easily no hacking of the stock harness on the ecu side, and on the engine side all I did was GM sensors so I could convert back if wanted.
Rob
ilotalo
Member
I have some maps, but i had evo3 pistons. Now i'm using dsm eeprom ecu. I can send you my settings if you want. Give me your email address.
janne
PMed you my email.
Why did you go back to dsm, if you don't mind me asking?
Did you not like the Megasquirt?
Rob
