MAP sensor plug
aggoos
Member
El Paso TX
I have a 2g head on a 1g block with a 1g ecu. The intake has a port for a MAP sensor that I don't need (using maf) The plug is leaking, letting in air under vacuum and letting out boost. Anyone know if there is a good aftermarket plug or of a technique to plug it up well?
Cheers,
Alan
raptorWagon
Oak Harbor, WA
It's not really a map sensor thay goes there, it's a MDP sensor as DSMs still use a MAF.
Either get it welded shut or make a blank off plate and rtv or jb weld it shut, or just get the sensor from a jubkyard and plug it with that all the same.
strokin4dr
Savannah, GA
Grab an evo 1-3 intake mani. They are a direct bolt-on, but have shorter runners, a 60mm TB bore so a 1g thotttlebody bolts right up, and it has no provision for the MDP sensor.
CutlassJim
Manchester, NH
Cause Evo III intake manifolds are super cheap and easy to find......NOT.
When I ran a 2G manifold I just installed a sensor from a junkyard and didn't hook it up to anything.
Quoting CutlassJim:
There are a bunch of them on Tuners: click
