SleepinGVR4
So my buddy is going to help me fine tune DSMLink for me. He told me to get a map sensor because it will be easier to compare actual boost to boostEST. I'm using a Evo8 Maf not SD.
So my question is how can I get the ECU to log the map sensor? I'm using the EGR input to log my wideband. Should I select narrowband simulation and use the 02 input for the map sensor? Its only temporary while we get it tuned. I can't use the IAT or Baro input to log actual boost while I'm still using a Mitsubishi Maf.
Anyone else do this?
