Major vibration on deceleration
dmj
orlando FL
My car just devoloped a major vibration as soon as i get of the gas or slowing down. the drive shaft was rebuilt less than 3000 miles ago all new oem carrier bearings , u joints and bolt shims. I have no vibrations on acceleration or highway speeds , hell I did a pull to 105 mph this morning to check for vibrations on hard acceleration and nothing.what should I be looking for other than loose bolts or a damaged u joint? /ubbthreads/images/graemlins/dunno.gif
belize1334
Bozeman, MT
This is a fairly common symptom and while there are many suggested fixes there has yet to be a solid diagnosis of the problem. Do so searching either here or on any of the larger DSM forums and you'll see that it comes up alot. CP had an extensive thread on this for his Road-Racing car. I've swapped transmissions, transfer-cases, and rear-differentials in an attempt to fix mine... all to no avail.
