Magnecor competion spark leads
Ok I have just had the very kind people at Magnecor make me up a set of competion leads after sending me leads for a 16v dohc and evo 1,it was discovered they did not list 1989-1992 GVR4 TURBO or have any upto date records,so they copied my old set and have given them part numbers as follows.
PT NO -40463 8MM COMPETION LEAD. PT NO -45463 8.5MM KV85 COMPETION LEAD
Hope someone finds this usefull,note these are for JDM not sure theres a difference but double check.cheers Guy
IncorpoRatedX
Arizona
if for JDM with cyclone manifold the wires will likely be longer as the coil pack is mounted in a different location.
