Lowering Springs. EU available?
miller_IRE
Member
Ireland
lads and lassies!
Looking for Lowering springs for my JDM Galant Vr4. My supplier of H&R reckons the options for the Galant are US only and not Europe.
Anyone this side of the pond have any clues or where to go for a decent set? Nothing major, just trying to drop it down a few mm.
Thanks
The part number is different than I have seen in the US, but the applications look correct by model.
I forget, do you have an E38 or E39. or some other model?
miller_IRE
Member
Ireland
Revisiting these. I am also in the market for new suspension. Not coilovers but keeping the OEM standards.
I see Rockauto has KYB adjustables in stock.
On their part list they list the Galant as a 2.0 DOHC. I guess this is the same for the VR4? I really want to make sure as I dont want to order the parts from the US shipped to Ireland and they turn out wrong!
KYB 741013 AGX listed for the Rears.
KYB 734005 AGX listed for the fronts.
Anyone else have these fitted to a VR4 and can confirm? I will most likely pair them with the HR springs listed above....
Thanks in advance!!
I have the AGX on my 91, which I made into homemade coilover setups.
On my 92 daily driver, I used the KYB standard application (I think for Eclipse GSX) and Eclipse AWD springs (fronts cut shorter). I really liked the ride/handling combo for the street and daily use. I don't have that car anymore, but it was decent set up.
miller_IRE
Member
Ireland
Cheers Iceman, RockAuto have those KYB replacements in stock. Ill dig further.
Its a pure OEM car, so a little lower but pliant road ride is what I'm after.
gvr4ever
central Indiana
Seems to be mixed reviews. I have AGXs and H&Rs and I like them. I think H&R revised them as some point, and I have the newest version. I wonder if that has to do with the wild differences in opinions. Might be a tad bouncy on bad, broken parts of the road, but compliant on most roads. Probably one level softer than I had on my Celica GTS that was a daily.
miller_IRE
Member
Ireland
@gvr4ever
Thanks, any chance you can post up the part numbers for the H&R springs you bought? Are they the 40mm drop. Would be brilliant to have a number I can cross reference. Sitting on an Island in the Atlantic its critical I get the part right first time as shipping back parts gets expensive!
Also the part numbers for the AGX's would be awesome too...
Thanks in advance....
gvr4ever
central Indiana
Looks like in the US, they have 1 part# for the whole kit, all four corners. PART# H&R 52974
As for the AGX,s they are for a 90,94 AWD DSM.
If you go this route, I recommend keeping the adjustment on the soft side to stay road compliant. Also, note that AGX doesn't warranty shocks that aren't on stock springs, and the lowering springs do seem to take some life out of them. From reading DSM forums over the years, I kind of got the impression that people tried to use the setup for racing. So they likely took a lot abuse. I don't have enough miles on mine to have an opinion on reliability yet.
gvr4ever
central Indiana
When I installed mine, I also used new top hat mounts and bump stops all around. Not sure if that would make a difference or not, but nothing was worn and I didn't have play in anything. I felt it just modernized the ride and got rid of that 4x4 90s ride.
Also using 205-55-15" tires on factory wheels. I could see having over sized plus sized wheels with little side wall, and having the AGXs on the hard side completely changing and or ruining the ride.
So, go all out and don't skimp on anything worn.
holeshotmoe
VA
I used the AGX shocks with DSM 1G springs. It lowered the car a bit over 1". I have the shocks set in the middle and I like the ride.
