low idle hunt.
James
Port richey Florida
this is a multi question thread...
A) where is the under dash plug to ground out when adjusted the BISS on a GSX. its not night next to the fuse box like on a VR4/DSM.
B) what causes a LOW idle hunt? Im reading idle hunt threads looking for info and they are all like 1200-2000ish, my idle hunt is 200rpm-1300rpm.
C) sometimes dies when coming to a stop, cant tell if its when i brake or when i push in the clutch.
Haven't investigated the ECU yet, i adjusted the BISS today, but i didn't ground off the plugs because i couldn't find the under dash one.
for referenc...
90 galant GSX
4g63T swap
Hard UICP
CX Racing greddy knockoff BOV recirculated
3inch turbo back exhaust straight through /magna flow muffler
MBC set to 13psi
desant78
Clarksboro, NJ
Also check out the vfaq on this subject. If you adjusted the biss with out grounding out the ecu weird things can happen. Did this problem just occur? Good luck.
James
Port richey Florida
I know Vfaq like the back of my hand, I've read it till my eyes bled then read some more over the years. I read talon digest while it was coming out, I'm not new to the 4g63 but I am new to the galant. (thus why I can't find the under dash plug).
I know these are all problem with high idle, the problem is I don't have a really high idle and I've checked about everything on that list before posting here, I was looking for more obscure reasons. While adjusting the BISS I head a small whistle of air though, I'll assume the BISS oRing is bad and start there.
