loud clicking from glovebox side of dash
Hey all- Just wanted to throw this out here and see if anyone can save me what could be hours. When I turn the key to the on position, BEFORE starting the VR4, sometimes, I get a loud clicking from the glove box area. I'm assuming it's a relay of some sort, fuel pump, but, that's just a guess. Obviously, the clicking stops after about 2-3 seconds and I fire it up and go. Any help would be appreciated. Thanks in advance!
Phil
Fever
Member
Lithuania
Its MFI relay:
evo8ya
PA/MD
Yup MFI relay. #259 had a bad ECU and what usually happends is the ECU will malfuntion causing the MFI relay to reset and click like crazy. I would pull the ECU and check the caps before it leaves you stranded on the road.
That is exactly the problem. The internal ground circuit for the fuel pump side of the relay is typically one damaged in the ECU and will cause this.
Terry Posten
Davenport, Iowa USA
Yes, pull the ECU and check to make sure your caps are not leaking.
Get it fixed fast or get ready to buy a new ECU.
Spend $50 now or $300+ in a few weeks.
Wow, thanks guys! You guys are awesome......Ok, I will pull the ECU ASAP and give it a check......Terry repairs ECU's is what you're saying? How do I contact him?
Ok, Terry Posten in this thread I'm assuming is who you mean...I read it so fast I didn't look at the names. I'm familiar with the capacitor probs in the ECU's as I have a talon, I'm just green to all the intracacies of the VR4's.......I will pull the ECU today and check it out......and report back.....thanks again!
