Loss of all MAF logging ECMlink
AuSpecVr4
Brisbane, QLD
Hi
Recently i have tried to install my clutch cut with no luck and now for some reason have lost all my MAF logging in live datalog. So, combinedft, maf Comp and raw, aswell as smooth rpm are all missing. If i check the DTC's i see error 0012 intake temperature circuit malfunction but the strange thing is if i unplug my maf while the car is off, it sense's the difference and stutters, same when i plug it back in. I havent touched any of the other ecu pins other then 104 which i cut, tried to put my clutch cut on, didn't work, and then have returned it back to the way it was. This might be a simple fix i don't know but i've checked all the ecmlink settings as best i know and i never remember changing anything.
Cheers.
