Looking for part numbers.
boostedinaz
Scottsdale, AZ
I already hit the part number list but didn't see a few things listed. I always double check to make sure I have the correct part number before ordering from my local dealer because they always screw up my order if I don't.
Looking for a few things.
Banjo bolt for the turbo oil feed that bolts to the head.
Banjo bolt for the coolant feed that goes on the front of the turbo.
-Need the two copper crush washers for the above coolant banjo bolt.
Any help is appreciated.
I don't know the part numbers as of yet because I'm at work but I'll look them up when i get home. I could recommend though that STM sells the whole kit to replace your hard lines, bolts, and washers for $50 and I belive they have free shipping. Im pretty sure one bolt is an M10 x 1.25 and the other is a M12 x 1.25. A little more info is when you install the bolt to the turbo for your coolant line torque spec is 31ft.lbs. and if you have the oil line off as well torque spec is 22ft.lbs. just in case you didn't know.
boostedinaz
Scottsdale, AZ
Thanks.
I would go for that kit, but this is just a stock car missing a few little pieces. if the parts the dealer quoted me are correct then it's only 29.00 for all these from Mitsu.
raptorWagon
Oak Harbor, WA
Prices as per Mitsubishiparts.net
MF650114 - 14x27 Turbo Coolant Banjo bolt - $5.88
MF660065 - Corresponding Crush washer - $.76
MF650113 - 12x23 Turbo side Oil feed Banjo bolt - $9.68
MF660064 - Corresponding Crush washer - $1.28
MF650102 - 10x20 Head side for Turbo Oil feed Banjo bolt - $11.48
MF660063 - Corresponding Crush washer - $1.09
Total
If you needed all new bolts and washers, not just one of each.
$46.58 + shipping
Prices as per Extremepsi.com
MF650114 - 14x27 Turbo Coolant Banjo bolt - $6.13
MF660065 - Corresponding Crush washer - $.75
MF650113 - 12x23 Turbo side Oil feed Banjo bolt - $8.13
MF660064 - Corresponding Crush washer - $.50
MF650102 - 10x20 Head side for Turbo Oil feed Banjo bolt - $8.13
MF660063 - Corresponding Crush washer - $.50
Total
All new hardware
$33.52 + shipping
Prices as per STM
10,12,14mm Crush washers - $1.00 each
Banjo bolts not listed, you would have to check with them. They are doing $2 shipping now, not the free shipping anymore.
Hope this helps
