LC1 wideband install
Tre3zy
South San Francisco, CA
can i use this link to install my LC1? 1g and gvr4 ecu pin out is the same correct? im planning on putting the LC1 on the front o2 location so i will need to simulate narrowband and also wants to log it... i just wanna make sure im cutting the right wire in the ECU for the LC1 input... thnx
EHmotorsports
Beaverton
Yep as long as its pin 4 o2 you should be fine.
This link is talking about another WB but same signal wires apply.
click,All_Forums,&Words=&Searchpage=1168&Limit=25&Main=1029716&Search=true&where=&Name=&daterange=&newerval=&newertype=&olderval=&oldertype=&bodyprev=
EHmotorsports
Beaverton
You still need to install the power,ground and ign from the innovate. But the signal wire from ecu to innovate will be pin 4
