Keydiver chip and knock sensor
Steve885
Concord ca
I have a keydiver chip set up for a 2.3 with the knock sensor built into the stock boost gauge..while driving in in boost I noticed it maxed out the gauge..how accurate is this gauge and could a little of it be the 2.3 with no balance shaft setting off the knock.I know I need LINK..
5OF2k
colorado springs, colorado
it's actually pretty accurate, if you log while youre doing the pulls you'll see the values rising with the guage in sequence. it's actually an effective tool for determining which points on the guage equal which values.
So, to sum it up, you're knocking a SHITLOAD.
Hope that helps!
-Jake
