keeping blowing ignition fuse trying to set idle
gotbl4d3
Active member
billings montana
Hey guys I was wondering if anybody has had an issue blowing a fuse
Grounding the two points to isolate the isc to set idle. I did notice there is another wire by the fire wall that was broken off I am not sure if I am grounding the wrong there or the one under the dash on the obd connector if somebody could give me some input that would be great Thanks.
gotbl4d3
Active member
billings montana
Okay so ground the other connector right next to it by the clutch master cylinder which pin do I ground on the obd plug?
