K-Tuned 90mm TB
89Patches
Ontario Canada
Probably one of the best throttle body you can buy, I've run these on a few big power cars now and have had no problems. Also everything uses an o-ring so no gaskets are needed. The end can be changed from 4" V-band, coupler and vanjen and are o-ring sealed as well.
Everything is +shipping and PP fees.
- K-Tuned TB W/ 4" V-band or 4" coupler adaptor & Ford TPS $350
- Magnus Remote IAC W/ OEM IAC motor $100
Jesus f*** those V3 manifolds are expensive. I don't think I've ever seen one go for under $750. Are they that awesome, or what?
KiNgMaRtY
Corona, CA
It is the best off the shelf manifold available for our cars. I am so tempted but I must resist.
4Grim
Orlando FL
Quoting GSTwithPSI:
Cast manifold, Magnus quality , and years of R&D with proven performance numbers....they are worth their price IMO.
JondoeVR4
Inland Empire, CA
Yea, R&D is top-notch. This is the only aftermarket intake I would run, if I could afford it. /ubbthreads/images/graemlins/dunno.gif I think I read that the runners are flow matched to within .3% @ 100 lbs/min and the plenum is around 3 liters. Good luck with sale!
jepherz
KC, Missouri
</font><blockquote><font class="small">Quoting GSTwithPSI:</font><hr />
You aren't going to mention the valve cover? Pretty sure that's twice the priceß
jeverts
Hartford, WI
Does that IAC work with ecmlink...the reason I ask is because this seems so simple that if I can use that with ecmlink I am just going make my one TB.
