J pipe?
Sam
Member
Riverside, CA
Does anyone still make it for our cars? The one that goes over the manifold. Found one site that says its for the vr4 but i think its the same one as the 1g or 2gs.
transparentdsm
Cherry Hill, NJ
Not the same as a 1G or a 2G. If you are looking for the stock OEM j-pipe you will need to find it for the Galant VR4. I'm sure someone has one in the for sale section. Try board member POT for an OEM.
Now if your trying to install an aftermarket front mount, you can make a 1G/2G 14b/16g j-pipe fit with it's down firing angle, but it requires work and patience.
A 14b/16g OEM j-pipe will not work in any way what so ever. It faces the complete opposite direction.
Sam
Member
Riverside, CA
Yeah, i wanted to use the 1g style but not sure about clearance. Im doing custom fmic so the condenser and radiator is out and replaced with the half radiator so ill have room to go straight to do a rear inlet intercooler. I saw that vw radiator fit perfect in where the condenser use to be but than im not sure if i would have the space for my intercooler piping. So much dilemma right.
Does it make that much of a difference to have that 2 inch j pipe? Its going into a evo 16g so if i use the oem one than just cut the hose a lil ways up than use a reducer coupling to sizer up than it would technically be the same thing right?
transparentdsm
Cherry Hill, NJ
The VW rad works great, if your going this route with a rear exit front mount intercooler then any cheap eBay j-pipe will work. Start with everything removed, then place the intercooler where you want it and build around it.
I have done this before myself. click
Somewhere in the middle of this thread I did the VW rad. Read through. I hope it help you.
Sam
Member
Riverside, CA
Thats a nice fitment. I always saw side pics of it, never actually seeing how much room was left.
Your intercooler looks exactly like mine so theres hope to make everything fit. Thanks for the big help
transparentdsm
Cherry Hill, NJ
I forget if it's an ets or vrsf, but it is for a 1G not a Galant and it fit really well. Just took a little work.
Edit: glad I could help.
slugsgomoo
Tacoma, WA
I had a 1g short route kit on my car, with the 1g j-pipe and it worked fine with the stock radiator with one caveat, and that was that I had to shift the radiator to the side (forget which, but search for one of my posts about radiators and there's a picture... I did it 13 years ago and can't remember off the top of my head). Piping fit fine, with a slim fan, though I still think it would be a problem with A/C...
