ISC test with megasquirt
turboflanagan
Peachtree Corners, Georgia, USA
I have a megasquirt computer running the Galant. I am unable to adjust my idle and need some testing input.
I have a new ISC and have verified battery voltage on pins 2 and 5 of the connector (the 2 middle ones).
To verify the computer is grounding the other terminals, could I just use a test light connected to the "hot" pins and each of the grounds while trying to actuate the ISC? That would verify both B+ and ground.
The ISC vibrates when actuated, but I can't see that it is moving much when trying to run it from opened to closed positions.
swe_gvr4_1991
Sweden, Alingsås
Did you wire in the MS yourself?
When we installed MS in my friends Volvo years back we simply did away with the ISC and used a stopper on the throttle. Then adjusted the warmup settings in MS. That way the car has perfect idle when warming and once it reaches normal operation temp.
Mdlimy
Gresham, oregon
I am not familiar with what type of isc this motor uses but I have done plenty of megasquirt setups along with various other ems installs so I should be able to help.
Is this a stepper motor or pwm? How many pins? Do you have a diagram/pinout for the isc motor?
Robbie
swe_gvr4_1991
Sweden, Alingsås
Yes it's a 6 pin unipolar stepper motor. Here's the schematic from the manual:
turboflanagan
Thanks for posting that.
I have increased the timed step size which helped get it moving when actuated. I have gotten the idle up a little bit, but it is still not consistently holding the idle I set at different temp points.
The isc is working. The computer is working. I think I must be missing something that is causing the idle not to remain consistent.
