isc 106 failed how do i test when thier is no fpr solenoid or boost sel.
construct1
New member
chicago il
i have a 92 vr4 sent in the ecu to have ecm link installed and was told isc 106 driver failed when tested. they installed a new one and are sending ecu back soon
my question is how do i fix this dont want to burnout the new one once my ecu comes back.106 is the fuel pressure selenioid, and boost control sel. as well. neither one of these are on my car nor can i find the wires that used to control those bought it that way, finding this out once i found out 106 is overheating, their are some unpluged connectors by my booster which ones are the fpr and boost solenoid
i know pin 57 on the ecu controls the fpr sel. nightmare trying to find anything on the internet on this
what is the simple solution here. where is the wire diagram for this
swe_gvr4_1991
Sweden, Alingsås
Easiest solution is to de-pin the ECU connector for those two solenoids since you don't have them anyway. If you ever need to use the outputs again you can re-pin the connector with flying leads.
Nightmare finding what?
Did you see this thread: click
Wiring diagrams for days here: click
IC106 controls the BCS and FPS. You'll need to either trace both circuits for shorts to power, or as swe_gvr4 said, de-pin 57 and 105 at the ECU connector (which is the safest option).
DSM ECU pinout: click
How to de-pin the connector: click
construct1
New member
chicago il
thanks guys thats what i figured id end up doing since thier not used anyway
im not an electrical genuis, i can build motors all kinds of other stuff but i suck at
electrical, i have depined many cars before, changed a bunch crx from odb0 to obd1 depining most of the wire harnes
what i meant about nightmare was if you type in isc 106 google and here you get almost all info on the throttle body issues,
when i took my ecu out and looked at it there did not appear to be anything wrong inside car ran fine except my lumpy idel from cams
its when they tested it did it show that it was overheating.
so from what im reading with guys having a no start issue after driving a while once engine is hot the fps was there for this reason
to take vacum away from the fuel rail..to help start in hot conditions and altitude.
thanks for all the info guys
