intake manifold?
tintoy
philippines
need help.. my intake manifold is a stock jdm. my friend gave me a stock usdm intake manifold, if i will use the usdm manifold would there be an increase in bhp? /ubbthreads/images/graemlins/confused.gif thank you for any answers and suggestions /ubbthreads/images/graemlins/smile.gif
tintoy
philippines
why? bcoz it had a short runner than the jdm? is the usdm intake manofold is the same whit the jdm NA manifold?
fuel
Toronto, ON, Canada
JDM is dual stage 'CYCLONE', ie there are two runners per port and half of the runners have butterflies controlled by a series of vacuum solenoids. Basically one runner per port is shut off below approx 4500rpm to promote turbulence which improves low down and mid-range torque but at high rpm the butterflies open leaving all runners open effectively flowing nearly as much as a JDM N/A or USDM inlet manifold. For high hp/boost applications the JDM Cyclone manifold can be a little restrictive, but for lower power applications it definitely helps improve low rpm performance.
tintoy
philippines
thank you sir for the info. i really appreciate it. i guess i'll just stick to the jdm cyclone manifold. /ubbthreads/images/graemlins/smile.gif. are there any mods that you can suggest on how to increase the high end hp oo a jdm cyclone manifold?
tintoy
philippines
thank you again.. i will post another question soon about a external fuel pump, is a boch pump and dont know how much lph it has. hope you can help me again. /ubbthreads/images/graemlins/smile.gif
