Intake Air Temps?
rdomeck
Indianapolis, In.
Ok, I am using a much different set up on my intercooler and today I did a log that involved small streets and then some interstate driving. Seems like my temps are good and they recovered quickly!
Would like some input on what you guys think once you look at the log!
Thanks,
rdomeck
Indianapolis, In.
I should have mentioned that this was done on an 80 degree day. My temps when pulling hard where running about 120 and cooled right down to 82-84 degree's when moving and stayed about 95-98 when I was sitting still shortly after I was on boost!
Seems good to me, but I'm kinda new to this!
I would like to see some back to back pulls and more aggressive driving to see. It all looks great in your log, but your not under heavy load for any long periods of time. I want to see what your logs look like if you run through the gears.
rdomeck
Indianapolis, In.
Log is posted on ecmlink! Link is above. I have pulled the car in to start body work, hopefully I can run it in a couple of days and see how it does. I had some makeshift duct work so I couldn't drive it far.
Thanks for the input
