Innovate LC-2 errors
AKGVR4
Member
Wasilla, Alaska
I am trying to install my new LC-2 wideband. I have attempted to follow the installation manual but once all installed I am getting 2 red flash error codes
1992 Galant VR4 I have connected the wiring as follows: Red wire to pin 107, yellow wire to pin 4 black wire to pin 106
5 amp blade fuse on control box end of red wire.
Red wire from control box and DB gauge all connected together with red wire from ECU pin 107
Yellow wire from control box, yellow and white wire for DB gauge connected with yellow wire from ECU pin 4
black wire from control box and DB gauge connected with black wire from eco pin 106
I am have left the stock O2 sensor in the o2 exhaust housing connected
I have installed a bung in my down pipe 20" from the flange.
The error flashes are all before I have even connected the wideband sensor
Any help would be appreciated
thomcasey
Indianapolis, IN
I believe I only ran the yellow wire to the ECU, for logging. Everything else goes to chassis ground and power connections. I trust new wire vs the 26 year old harness wiring. You probably aren't getting enough power to heat it up from either a ground or power issue.
AKGVR4
Member
Wasilla, Alaska
I followed the ecmlink guidance on the wiring. I will try to change that to direct to switched power and the ground at the battery Hope it helps
