Injector plug wires
Brunoboy
San Bruno,CA Home of SFO
Hey guys, so i was wondering something , i replaced injector clips and i hooked up the wires however i thiught it was supposed to, the shop my cars at does a lot of dsms and told me my injector is gettin positive power to both sides of the wires, is that not ok? He said its only supposed to be one side positive power.
-shane
toybreaker
iconoclast
Shane,
It's quite possible he's checking it still plugged into the injector with the key on, and the engine not running.
If that's the case, bith sides will read positive potential, as the ecu provides the ground only when it wants to have the injector firing.
Have him disconnect the harness connector from the injector, and check it again.
If it still shows voltage on both pins, then you'se got troubles.
cheekychimp
East Sussex, U.K.
/ubbthreads/images/graemlins/worthy.gif
I was about to say exactly the same thing ... NOT! Where the hell do you learn all this stuff John?
toybreaker
iconoclast
By doing it wrong myself.
... and then having to figure out how/what I borked up ...
/ubbthreads/images/graemlins/rofl.gif
toybreaker
iconoclast
What is the actuall problem you are having that is causing you to check for voltage at the injector connectors?
Brunoboy
something like that ^^^, IDK what to do, So you say that Injectors are supposed to pulse when firing? if so, which side of the wire on each plug do I check?
-Shane
toybreaker
iconoclast
Shane,
Popping multiple ecu's sucks. /ubbthreads/images/graemlins/frown.gif
I would be happy to talk to your shop guys, as it'll be easier than typing long posts out, so I'll pm you my phone number.
Can you list your mods, (specifically which injectors you're running), and shoot some pics of the damaged ecu's?
Thanks,
John
