idle surge
AllanL
NV
any advice on what needs to be checked/cleaned?
car idles fine, boosts good...except that while slowly stepping on the pedal and upon reaching and staying in the 1.2krpm range, idle surges...
but stepping harder on the pedal and leaving this rpm range, revs will continue...
thanks!
4Grim
Orlando FL
Have you checked for any leaks on the hot side? Piping from the I/C to the throttle body?
I had a similar issue years ago and found out I had a leak from the TB.
