Idle Misfire *vid*
thecman02
Kalamazoo,MI
On my search to find why my car is misfiring I came across a video that captures the sound of the misfire I'm getting at idle. I'm struggling to figure out what it is. Here is the video. Misfire Vid If you listen there's a tiny backfire.
Notes on the car.
185 compression on all cylinders.
Spark Plugs have 1000 miles.
Fuel Filter 1000 miles old.
FIC 1100cc injectors were cleaned within the last year and has been run with e85 too.
Engine was rebuilt 1000 miles ago.
Base timing at 5 degrees.
Idle Set 800.
Fuel Pressure is around 28ish psi with vacuum source connected.
No Boost Leaks.
The car pulls cleanly on boost most of the time.
It misfires at operating temperature and cold.
It misfires whether using e85 or 93 tuned appropriately.
Fuel Trim is lo hovers around 100% +- 10%. Mid is at 100% Hi is at 106%
Has anyone had a misfire like the one in the video?
Things I'm going to check in the next day or so is disabling individual cylinders with my logger to see if I can isolate the cylinder/cylinders giving me the problem.
