Idle issues
presterone
brunswick maine
I have no idle speed control so I'm hoping this is why intermittently my car will surge at idle. I'm sure some of you have run with no idle control before, my car will raise to about 1500rpm and then drop and it does this rythmically when it idles for a little more than ten seconds, sometimes sooner like slowing down from the highway with no throttle input.
presterone
brunswick maine
No boost leaks and I haven't looked much into what it is yet because I was 90% sure it was due to having no ISC. And I should say a few things about my setup its a speed density ECU ''jackal'' with just a MAP and IAT sensor, that may help pinpoint whats going on since I don't have to worry as much about vac leaks. It may be related to my tune or something but I was mostly just posting here to see if this condition was common with no idle speed control.
