I Know...another Oil Question
Chad989of2000
Livermore, CA
Hey guys, I've always used Mobil 1 10w30 since I lived in an area that actually hosted winter. Now that I'm in the bay area can I run 5W30 or is there a preferred weight? Car will not see much DD, it will primarily be used for fun motoring and track days. Just looking for personal preferences on similar applications.
EMX5636
Bucks County, PA
I ran Mobil 1 15w50 for the first probably 20k of this engine. Loved it. Towards the end though, it seemed like it was getting thinner and thinner out of the bottle and causing more and more little drips. I swapped to Valvoline VR1 20w50 for the last 5k or so, and have been as happy as I was with M1 in the beginning. Apparently they changed their formulations a couple years ago, and most people have noticed. /ubbthreads/images/graemlins/frown.gif
Chad989of2000
Livermore, CA
I've heard good things about the VR1. I run Royal Purple in the spec.B and like that just fine. I just wanted to see what the board users were using on their cars.
turbohf
Lake Stevens, WA
I run the vr1 20w50... she cranks a little slow in the winter and the lifters arnt happy (new lifters in mail).
ktmrider
Tempe, AZ
Quoting transparentdsm:
im up in tahoe and i run rotella t6 15w40 all year long, but the car doesnt get out on the roadto often in the winter.
This is what most of the folks I consider 4G63T smart suggest ( at least the weight ). Rotella T6 has lots of great oil analysis data by users to sway me to their product(s) and the lower price is a total bonus.
ktmrider
Tempe, AZ
Quoting prove_it:
I run the basic rotella. I haven't even bothered with T6. It is better, but still good.
Run both too, seemed like I got less coking/burn-off with the T6 ( less refill of oil between changes by like 1/2 qt ).
JamesFoster
ALL
Brad penn 20-w50 here. Have used vr1 in the past as well, good oil, I like BP better.
BpuVR4
Chicago
Quoting turbohf:
how cold are your winters? i try to run vr1 in the warm times, but once temperature starts hitting 40's, I switch to Rotella T6. It just takes too long to warm up the motor w the 20w50, dont have the patience for that.
BpuVR4
Chicago
Quoting prove_it:
I love the 15w40 Rotella, very good for the money in my opinion. I only use the T6 for wintertime.
EMX5636
Bucks County, PA
I would stay as thick as possible with oil. 10 or 15w40 being minimum if the car will see a lot of RPM. I think it was Kiggly who did testing on the stock pump, the thinner oils don't support the pump gears as well and it was shortening the lift of the oil pump and bearings. It wasn't even a HP thing. bobistheoilguy.com is actually a really good factual forum for oils. There are a bunch of back to back and group testing for all kinds of petroleum products. I chose VR1 over the Brad Penn from some test info over there.
diambo4life
Edmond, Oklahoma
Don't use 20W-50 oil in freezing weather (below 32*F) and if you run E85, don't use Brad Penn. 10W-30 is actually a good all weather oil weight. I use 10W-40 in the winter and 20W-50 elsewhere. There's no need to run 5W-30 in Cali.
EMX5636
Bucks County, PA
I ran 15w50 Mobil 1 and now VR1 20w50 all year in PA and it regularly gets below freezing all winter. No issues, pressure comes up quickly and has been fine for 26+ thousand miles on this engine. /ubbthreads/images/graemlins/dunno.gif I guess I don't abide by the rules.
Not saying you can't run 10w30 or it's a bad idea, just running a 20w isn't necessarily bad either, especially in a slightly looser than factory engine build. Can't comment on the E85 suggestion though.
ApexHunter
Marysville, WA
Rotella T6 in my evo, and i've used it in various cars over the years. 3k mi intervals in the evo, which sees 90% street/crusing. Considering the UOAs that come back on it, it's really tough to beat at that price point.
turbohf
Lake Stevens, WA
Quoting BpuVR4:
Quoting turbohf:
seem to get a 10F day or two out the year. but the galant is parked outside and frozen over at that point. but im pretty sure i have lit her off on a 19F day. plenty of 25-30F days. it does take a while to warm up, and like i said, lifters seem pissed off forsure.
i usually have 2-3 cars. and one will always be in garage, so it will be lest cold and not frosted over. plus im usually late, so that has won in the past.
