i just took my first ECMlink log
mikus
Aurora IL
... and can't tell you much from it, but it's gratifying to start moving past maintenance/parked and into a daily driver. yea that's all, just had to tell someone and the wife does not care.
Wideband goes in this weekend, and switch from maft to SD soon.
dewman
AR
/ubbthreads/images/graemlins/rofl.gif They never do... /ubbthreads/images/graemlins/dunno.gif
What all did you log?
mikus
Aurora IL
... a bunch of lines /ubbthreads/images/graemlins/dunno.gif /ubbthreads/images/graemlins/rofl.gif
yea whatever it defaults to, on a couple pulls. I was just screwing around, the car is a side project for me.
For the record the wife cared about my pretty vr4. This one's pretty wookie.
vtecds1
Las Begas
Will be logging mine also for the first time hopefully by Sunday. I have no clue what the hell I`m doing, so I have to read up quick so that I can at least drive up to the mall and pick up some cougars...
Dark_Horse
Morrison, CO
There are a few variables that it's helpful to log. At a minimum, I'd log the following:
Combined fuel trim
Throttle Position
Timing
RPM
Injector duty cycle
Coolant temp
Airflow per rev
Knock
O2 volts
Open loop
Closed loop
Idle switch
MAF Raw
beaner
b'ham, mi
I feel like I watched these vids 20x. They literally spoon feed you how to do the basics.
Make certain you have no boost leaks and your CAS is adjusted correct. Adjust your TPS correctly with link before even turning the key. Capture your ISCposition so we can adjust that and the BISS to where it should be.
Post a log and I'll help my best.
Dark_Horse
Morrison, CO
Worth the $195 to upgrade to V3? Definitely. I wasn't sure whether it was worth it either, but I decided to give it a try. After I got over the initial learning curve, there's no way in hell I'd go back to V2.0 again.
