i found my old thread, exhaust questions
Brunoboy
San Bruno,CA Home of SFO
this is how my exhaust is currently:
After re reading, Garfield said I can push my muffler back farther back and I looked today and it seems that I can a bit. Does anyone else have pics of where their exhaust sits? Also this is a full 3' turboback, will decreasing the 3' tip to a 2.25 tip for more sleeper look make a huge difference?:
PreskitVR4
Prescott, Northern AZ
Depends on your power level. If you choose a muffler with dual outlet like the stocker, then you will prolly give up nothing. Going with that small of a tip, will give you cool vacuum cleaner sound under boost.
Brunoboy
I am aiming for a 400awhp DD, but at the moment I have mid to high 200. I am not changing mufflers btw, I was just going to downsize the tip like the dsmtuners post. The muffler in the dsmtuners post and mine are the exact same company except that has two outlets. would it flow better with two tips at a smaller diameter than my single with a smaller tip?
-Shane
raptorWagon
Oak Harbor, WA
Well if you look back in your old thread, you will see the pics of 1350 with the dual 3" outlet. It actually sat about even with the fuel tank, so if I had thrown a JDM bumper it would still be flush. It would flow better if you didn't change it from a 3" to a 2.25".
