How much timing to run
deez
Chico, CA
I keep getting knock, and found that I can get rid of it by running only 2* timing. That really takes away from power compared to the stock 5*. Does anyone else run this little timing, or should I be trying to get rid of knock from some other approach?
What else are you tuning with? Under what conditions do you see knock (rpm/load) and how much?
ktmrider
Tempe, AZ
You shouldn't need to reduce the base timing unless running huge boost.
Too hot plugs, reduced fuel pressure, injectors sticking, crappy gas, etc. You got a logger?!?
Edd,
You should email me your address so I can mail out a new chip, as your's has pretty old maps. You only have 91 octane, right? Stock compression? What altitude? How much boost are you trying to run with that much knock?
deez
Chico, CA
My mods are listed at the link on my post, but I will email you also. Thanks Jeff. And as for the knock, its around 4200rpm, 20psi on an E16G, and about 3/4 throttle to WOT. I also pull some random knock around 3k, when under a load and not much boost. Its pulling about 2 bars on the old boost gauge, so however much knock that is.
deez
Chico, CA
Oh ya, tuning with a logger and SAFC, new BPR7ES plugs, stock fuel pressure, 91 octane (the best I can get here), 20psi on an E16G.
