High Idle
Okayplayer
Denver, CO
Sorry for adding another thread on idle problems, but the search function doesn't work at my job. I recently have done a lot of work to my motor, including rebuilding the bottom end because of a spun bearing /ubbthreads/images/graemlins/banghead.gif . Now I have it back together and it is running well all except for the idle. It starts at about 900 rpm and by the time it gets to operating temp it jumps to around 1500. If I continue driving it, it goes clear up to 2500 and sometimes higher. I changed the isc a couple months ago and I just change the coolant temp sensor. I did a boost leak check on it and that is good... so what am I missing here? any ideas? /ubbthreads/images/graemlins/uhh.gif
Okayplayer
Denver, CO
I was starting to think along those lines as well. But would it idle that high? I am going to look into blocking that. Would it suffice to do the valve turn like in the how to section? Or should I completely remove it?
unistylef
San Diego, CA
I had that issue. I had to test resist on the 6 pins for about 30+ ohms on the isc. Currently, I have the isc motor inside with power disconnected and the motor on the "in" position. Then I just adjusted my idle screw to allow more air.
