Hesitations while driving.
Perkul8r
Mandan, ND
Ok. So after I got my Galant and got it going again to use as my daily driver, I have found one issue.
Sometimes when accelerating the car will feel like its missing or hesitating. If you continue to try and keep accelling and trying to get into boost the motor just cuts out. Almost like its hitting a fuel cut. When this happens if you are just easing into the throttle it just seems to hesitate or miss.
Now this doe snot happen all the time. It does happen quite often. Sometimes multiple times during the day. And other times it works great. You can run the car up into boost (6psi is all I am running till I get this sorted out) and have no problems. The Check engine light does come on. But I haven't been able to get that figured out. I tried checking it without a logger or scanner, but couldn't figure out the code. I do ahve a logger coming. I just bought it last week.
I was jsut trying to see if anyone would have any ideas on this. I am trying to get it fixed so I can finally have some fun and possibly AutoX this year. So I am open to any suggestions.
Thanks
Oh car Info:
120,000 miles on motor, Emissions removed, EGR removed, Hallman MBC, Evo 3 exhaust mani, 16G, plugs and wires just replaced, everything else stock. Car has been doing this since I bought it, but had to replace trans first. Car was completely stock when I bought.
jmorri15
Kemp, TX
check your throttle postion sensor(on the front of the throttle body), i had some oil that got on the connector so the ecu didnt know i was trying to open the throttle, cleaned it off and the problem went away.
Perkul8r
Mandan, ND
Got the logger all setup and working. And checked the DTC's right away. 2 came up. MAF sensor and TPS. I erased them cause I did forget to plug my maf back in yesterday when doing some work and I wanted to see what came back up. Well. The tps one keeps coming back up. So I am gonna check it out, probably just replace it. The car is 20 years old with stock equipment on it.
stealthtt24
Orlando, FL
I have the same problem, my hesitation is f***ing terrible. Does it 80% of the time and at idle as well. It sounds like a Subaru motor! Usually goes away after 3k. I plan on replacing the fuel filter and sending off the aftermarket injectors for cleaning. I'm not getting a check engine light though. Any other thoughts?
jmorri15
Kemp, TX
fuel filter would be worse the more fuel it had to pass. so low rpm would run better then high
donkeylips
Rochester, NY
Quoting stealthtt24:
Do you have a logger? Log your MAF, TPS, etc and you should find the problem. Also make sure your base timing is set right.
stealthtt24
Orlando, FL
I figured it out. The second previous owner jerry rigged the bov return hose. We capped off the hole at the intake and it runs much better. We plan on cutting and welding the line this weekend but I know the car has boost leaks as well.
jmorri15
Kemp, TX
if it was a boost leak i was thinking it would not be intermittent it would be a problem all the time so logic dictated it should be another problem. but we see how logic works on these cars. lol
Perkul8r
Mandan, ND
Well. Now I got my data logger I have figured a couple things out. First of, yes the tps is shot. I was watching it while drving back home cruising at 65 mph and it was at 0.0% on the logger for most the time. I have also found out that my alt is dying, my oil pressure is around 10 psi at idle-not sure what its supposed to be at and my coolant temp sensor never goes over 189. So I have some thing I gotta figure out now.
