Hittman
I've searched a couple of terms and found some threads, but none applied to me (or at least they didnt seem to)
I'm having a problem with hesitation when throttle is applied, upon lessening up on the throttle, it seems that the car accelerates a bit more. This appears to be evident in 1st through 3rd gear, but seems to taper off in 4th and 5th. I had a similar problem in my Evo, but it turned out to be a loose hose (I/C Piping Hose), didnt know if thats where I should start on this issue, or if this sounds like a different problem. Any help is appreciated.
