PJGross
This is definitely a newb question so here goes:
Installing a Raxle passenger front shaft today. New axle seal in, attempt to insert axle, no go.
I sent back my core last year but I know I compared the two and they looked fine. The C clip does appear pretty stout on this and the ends are out at least a 1/16 of an inch, but before I do anything stupid I wanted to double check:
Axle binds about 1 to 1.5" from seating. Definitely engages the splines no problem.
Can someone reassure me of the engagement dimensions? 3" from tip of spline to axle cup, splines a little under 1.5", about 1" of smooth, then the shoulder is about 1/2". Sound about right?
Am I just a 225lb wuss or what? Everything I read says it should just pop back in.
Just didn't want to bust something.
Thanks,
PJ
Thanks,
PJ
