Help me identify starting issue
lalo
Member
Los Angeles, CA
Hey guys I'm new to the mitsubishi world and this website and I'm having a problems with my vr4.
Here's a video to show what's happening
I don't know if there's a way to post a video directly but here it is.
I already tried changing the battery and nothing. I don't know if having the battery in the trunk might be affecting this . I need suggestions from the vr4 gurus. Thank you /ubbthreads/images/graemlins/smile.gif
transparentdsm
Cherry Hill, NJ
hahahahahaha we need more information then help me identify starting issue. like whats going on? what does the car have done. are you mechanically inclined?
lalo
Member
Los Angeles, CA
I'm so sorry I accidentally clicked continue without finishing my post and to
Answer you question yes I do my own work. Electrical stuff usually
Stumps me though.
transparentdsm
Cherry Hill, NJ
ok so i cant see the video, can you explain symptoms? if its a short id say check all the wiring to the battery, maybe metal cut the sleeve and shorted it, if its clicking then try smacking the starter with a rod and hammer, if power comes on the dash and there is no click it will be your actual ignition and its the triangle 3 plug under the hood by the area the stock battery sits.
edit: also check the MPI, Transistor pack, CAS and ECU.
another edit: if its a hot start issue check the CTS and all its wiring.
lalo
Member
Los Angeles, CA
The symptoms are that you can hear a weird noise when it's trying to turn like wshhhhhhhh. All the lights on the dash turn on and everything works. I need to know where I can locate all the things you mentioned. Btw before this started happening the car was alright but one day I left the car sitting for a week with one of the dome lights on and the battery died I changed the battery and then this starting problem began.
Edit- no it does it hot or cold
transparentdsm
Cherry Hill, NJ
ok if you can get it running put a DDM on the alternator and make sure you see 14.5-14.7. if your jump it does it turn on? id also try smacking the starter with a rod and hammer. might be a locked starter.
edit: i had a starter lock from push starting my one time. and once when i put my old auto in neutral and moved it 15 feet forward.
transparentdsm
Cherry Hill, NJ
MPI is under glove box, by the ECU, transistor pack is on the intake manifold by the coil pack and wires and CAS is on the motor,opposite side of timing belt in the back. CTS dont worry about at all.
lalo
Member
Los Angeles, CA
It starts but it takes it like 30 second and it struggles almost like no current is going through eventually it does turn on.
lalo
Member
Los Angeles, CA
@G were u able to watch my video?
Okay I will make sure that all my grounds are good
But that will be tomorrow because it's already 9pm here
