Help ID a pair of cams please?
ohmegamike
Solon, IA
Hey Guys, I picked up some cams and other DSM stuff from a guy. He claimed the cams were from a Buschur Head (2G DSM). I'm thinking about putting them in my galant. The intake cam has numbers engraved on it that read:
101-201-8I, then below that it says UI2802, there is also two c's engraved (c c) I'm assuming Crower?
The exhaust cam says: XE258HR below that is a -111, and UI2614. This one has the same c c engraved also.
I tried to take some photos, but they were pretty worthless. If that's what it's gonna take, I can give it another try. I did a little google searching and came up with zip... Thanks in advance!
-Mike
ohmegamike
Solon, IA
No ideas? Anybody know if crower's have nothing more than c c hand engraved? I guess I will just call them...
ohmegamike
Solon, IA
OK, I found this on carolinadsm So I think I got one figured out. FP2 Cams...
258 Exhaust
Grind: XE258HR-111
Valve Adjustment HYD
Gross Valve Lift .395
Cam Lobe Lift .232
ADV DUR @ .004 Valve Lift 258
Valve timing @ .050. 46 BBD 14- ATD
These specs are for cams installed @ 120.0 Center Line
Duration @ .050 212
