Help finding a tread.
citymunky
Chesapeake, VA
I been looking for the last 2 hours for the tread where somebody modding there stock clock into a Wideband O2 by using a Innovate Motorsports DB gauge.
Since I hate A-pillar gauge pods, and I will be installing a Double Din DVD player, I'm running out of places to install gauges. I'm trying to use 5, and 4 are going in the center A/C vent.
-Wideband
-Boost
-Oil pressure
-Oil temp
-Water temp
moduleunknown
Elk Grove, CA
That was probably me.
I still haven't installed it into the dash yet, only mounted the internal bits of the gauge to the clock housing and verified that the gauge still works.
It's low on my list of items that need attention right now so I can't tell you how involved stuffing it back into the clock location may be. I can tell you though that it will be absolutely necessary to cut out a channel in the plastic frame inside/behind the dash for the pc board to slide back into that hole as it's taller than the housing for the clock. It won't just go straight in - will need to angle it in, then slide it back (through a channel you've hacked out).
If you look through my recent posts, you'll find pics in a thread about "post your interior gauge setup's", or something of that nature.
citymunky
Chesapeake, VA
Yes it was. I just searched your post to find it. Thanks
Here the link if anybody wants to know what I'm talking about
Link
