Headlight Problem
Ok so I'm driving at night and all of a sudden only the headlights go out. No the cluster or corners just the headlights, then when I push the brake pedal, they come back on again, but when I release the brake pedal they go rite back out again. Here's what's weird though. When they go out instead of pushing the brake i put the high beams on and they came back on. What the hell is causing this? /ubbthreads/images/graemlins/banghead.gif
You have some serious wiring issues. Did the PO do any electrical work to the car?
maroonmetallic
central WI
From your original pictures of the car, it looks like the car might have HID's. If that's the case, I'd check wiring.
You def. have some funky wiring someplace!
Ok just thought I'd share the solution to my weird electrical problem. It was the alt. Now if anybody ever shares this same symptom hopefully this helps.
