GTX3576R Gen II
rocket_b
New member
Anchorage, AK
So I have a GTX3576R Gen II and I was wondering if any of you have this turbo or a similar one on your GVR4. If so what power did you make with what fuel and was meth spraying or not. Trying to get a feel for what kind of power this turbo will do with meth. And whether I want to go with this one or the GTX3076R for my build.
strokin4dr
Savannah, GA
I have a Garrett 3582 in a bolton FP housing. I'm still in the process of gradually increasing the boost and tuning it on pump 93. So far, at 25-26 psi with conservative timing, ECMlink estimates ~480-490ish whp.
I will keep going and try to max out the 93 oct tune, and then dump in some E85 and start the tuning process again.
The turbo is pretty quick spooling with the FP exhaust housing on a 9:1 2.3L build with Kelford 272s.
MX4
New Zealand
I have the same turbo setup at Strokin4dr, also with the Kelford 272's but on a 2.0 litre. I'm running 98RON which is equivalent to pump 93 in the states. For the 2 litre it is quite laggy but does make good power. Approx 420hp at the wheels on 26psi.
