Greddy E-Manage Ultimate><dsm link v3 lite
MitchooO
South Mountain, PA
i am gathering the final major peices and dont want to leave out the ecu...i was thinking on the new dsm link or w/e its called, ecm link? but i have been talking my friend who has just got done taking the classes at efi university and we have looked very hard at wat i really need to run my setup and the e manage ultimate seems like a good way, but havent heard much about them yet. so if anyone could give me a little feedback or comment on wat they may have heard it would be great, it is a decked .40 over block, stock crank, manley I beams, ross 8.5:1 with a new slowboy head, cometic gasket, arp studs, stock cams for now, factory port im guessing.. with 850cc injectors stock intake mani for now, a long tube top mount with 44mm gate, GT4094r twinscroll t4, 2.5 IC piping all the way to the TB with GM 3" maft setup....i think thats all...so i guess wat im asking... has anyone tried the ultimate yet? or any evo guys that have with close the the same setup.. thanks for any replies!
- also... i plan on buying the extra sensors to run all the necesary equipment to use the emanage to its full potential and run a map setup instead of the maf
E-manage ultimate is a VPC you control from your laptop. It's still a piggy-back.
My suggestion is running a 3 Bar MAP, DS-map, and an ostrich for real time up/downloads of BINs.
All can be had for around $350
Andy_S
Shithole Wisconsin
The mr2 guys love it, but they don't have many solutions since there is nothing you can do with an oem ecu. It still is essentially a piggyback, but it intercepts at the injectors instead of the airflow signal. Its way better than a safc in that regard. In my opinion though, the dsm ecu has many great solutions that are native and very powerful. Ecmlink, ostrich, or a chip will be better considering it isn't a piggyback.
In the end though, you will most likely reach the same results with whatever route you chosse.
Telecaster
San Jose, CA or Philippines
Ecmlink is a lot more easier with its interface. Not only that but they have a very good forum to help you out. All you have to do is post a log and you'll get pretty good feed back. I've also heard some things on emanage burning out ignition coils.
Scientist
Roseau/Dominica
I've done E-manage installs and base tunes on 5 cars thus far. Its pretty powerful and Can do quite a lot. Haven't had any issues with them except for mistakes made during initial wiring or once one of the car specific harness' had a cold joint.
Next month I'm going to be converting a VVTi 2JZ-GTE supra to use a GM 3.5 bar map sensor with the E-manage since those cars came equipped with MAFs
i would use dsmlink. the price really cant be beat for features, ease of use, and install.
MitchooO
South Mountain, PA
all i want to make sure of is that i can setup aintilag between shifts and for launching at the strip... and be able to control any fuel or timing map possible... can dsm link do the antilag stuff?
brisvr4
brisbane australia
Dsmlink has antilag and you have good control over timing and afr maps as well.
Have a look at the site over there and that will give you all the info you are looking for.
I run antilag and NLTS and love it!
MitchooO
South Mountain, PA
i think im going to go with dsm link or the dsmap setup...but definetly the v3 lite if it has everything i need...i am far from being anything close to someone who can tune..but my friend is willing to show me some basics and i know dsmlink has wayyy better support than greddy lol.. i read about the lite still having antilag and speed density setups, is anyone running the lite? instead of the twice as expensive full v3?
BoostedAWD91
Danville,Pa
i am in the same predicament between goin with dsmlink v3 or ds-map. DS-Map is fairly cheap but its only around $200 less than dsmlink. If i decide to go with Dsmlink im not sure which configuraton to use. one of the mafs or speed density
raptorWagon
Oak Harbor, WA
Quoting BoostedAWD91:
DS-map is still in its' beta and free, you're only paying for the parts; map sensor, iat sensor and bung, ostrich and a wideband if you don't already have one. Also if you really want plug n play for the map & iat sensors to the maf plug you can get the harness off of FullThrottleSpeed.com SD 1g Harness . Whatever floats your boat though /ubbthreads/images/graemlins/dunno.gif.
