gauges
galantgti
netherlands
A couple years back I was looking for gauges with almost the same greenish background color as the lights in the dash have. Found them, but never got around to buy them and now I've forgotten which brand they were.
So, does anyone have gauges which match the OEM greenish colors of the dash?
You can remove the green stock lighting and match all your gauge bulbs to the cluster.
That is unless you like the green.
pot
Fayetteville, NC
Dennis check out egauges.com
My personal favorite gauges are VDO and the bulb comes with a green condom that makes both the gauge and the color nearly identical to the stock instrument cluster. I use their boost and water temperature "Vision" line on 182.
