Gas light help
Diego
hey guys... need help so lets help.
uhm gas light doesnt come on anymore did before i parked it for tranny issue.
previous problem was the needle doesnt even move so it stays a lil under half tank..
whats the easy fix for this...
is it relay related or something else? /ubbthreads/images/graemlins/confused.gif
sounds like the arm on the sending unit may be stuck. Pull it out and take a look.
solidviper89
Mission/ San Antonio, Texas
i have another question didnt want to start a new thread...
my light turns on even with full tank, then turns off randomly when it get below 1/2 tank, then it turns back on when its low... /ubbthreads/images/graemlins/grin.gif
Its been like that since i bought it! i dont even car for that light anymore! My gauge is accurate, ask me how i know ... /ubbthreads/images/graemlins/blush.gif
BoostedAWD91
Danville,Pa
the float arm on ur sending unit sounds likes its stuck or its shorted out.
like jesse said check the function of the float arm and then the wiring and go from there
Hertz
Chicago, IL
Quoting BoostedAWD91:
I thought the float arm only controlled the level gauge and a different sensor/float was used for the idiot light.
I would suspect a bad ground/wire.
jepherz
KC, Missouri
Yeah, that's right hertz. You can see what he's talking about if you just remove the sending unit.
BoostedAWD91
Danville,Pa
could be true, i figured since the float was used for the gauge level it would be used for the idiot light as well, guess i was wrong there
Diego
well its been like that since i bought it.. the level STAYS at like 1/4 tank and never moves... there is a wire unhooked in my trunk that runs my wally255 (rewired) so maybe thats my ground i asked a buddy of mine if he knew what the random wire was and he didnt have a clue maybe its my ground ill check it out tonight..
what should we normallly get for mileage on a full tank?? 230mpt??
oh and mods can anyone pull up any info on 1309's previous owners.... i want to see more post of my car... cant find any... its been over a year and change since ive owned this car and never was able to find info. thanks
