GALANT PROBLEM
Hi guys again.
something happens to my car, does not work well.
I made a short video .... click
DR1665
Iowa City, IA
Not enough information to really offer any advice, man.
Looks like idle is where it should be, though the dropping like that isn't right (obviously). Does it act this way once it's warmed-up? How does it drive, otherwise? Is the coolant temp sensor working? Do you have a datalogger to see what the ECU is seeing from the sensors? Did you recently perform any modifications?
Well, start with the normal stuff. Pull plugs, check injectors, compression etc. You might want to re-set the idle as well. Dosen't seem to miss when you rev it? Does it do weird sh*t when you drive?
When cold it does not ... it makes when heated. I checked all the cables are well injectors, compression is good.
It is interesting that when hooking up a computer, it shows that everything is OK.
When i drive it ... the problem is gone,engine sounds perfect...the problem is when the car stopt, and after 1,2 minute problem appears.
Could it be throttle ???...
bazeng
Melbourne, Australia
Id say it is your biss adjustment on your tb. The idle screw was probably set cold. Get it to completely warm up, gnd your timing connector in you engines bay and adjust the screw on your throttle body. vfaq.com will show you the exact procedure. Basically when cold, your cold start is allowing enough air through to idle at 1k rpm. Once the cold start disables, your idle drops. You need it to cold start around 1.5+ k rpm and idle at 800 when warm.
desant78
Clarksboro, NJ
i had the same issue and went through the vfaq and it solved the issue. When the car was cold, the car ran a little rich and the problem never occured. Once the car warmed up, and went into a "closed loop" using the engine temp, all hell broke loose and I had the same problem.
In the end, i got the block off plate for the FIAV and installed it on my throttle body, and had to adjust the BISS (throttle body screw). As always make sure your timing is set correctly and your TPS is set up correctly too.
p.s. what do you mean you hooked up a computer and it said everything was fine? if you have a logger, can you post some information while you were idling?
Good luck!
I dont have logger.
We made a diagnosis in computer service and showed that everything is okay ... this is impossible because my car die at idle. sh*t !!!!!!
Is it possible to have a boost leak or vacuum leak somewhere ....????
